robdyck Posted November 18, 2021 Share Posted November 18, 2021 Is there a way to assign a hot key to go straight to the label text of an object after single clicking on the object? I use a lot of labels, and I'd lick a hot key that goes to the label and highlights the existing text so its instantly ready for new text to be entered. Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted November 18, 2021 Solution Share Posted November 18, 2021 5 hours ago, robdyck said: Is there a way to assign a hot key to go straight to the label text of an object after single clicking on the object? I use a lot of labels, and I'd lick a hot key that goes to the label and highlights the existing text so its instantly ready for new text to be entered. Yes, but not within chief. you can create a macro that will do a continuation of ctrl+e and a bunch of tabs. have you considered changing your preferences to open up to the last panel. Not in front of a computer right now. 1 Link to comment Share on other sites More sharing options...
robdyck Posted November 18, 2021 Author Share Posted November 18, 2021 @Renerabbitt Thanks Rene, I appreciate the advice. Open to last panel will do just fine until the weekend! Then I'll take a look at a macro recorder. Link to comment Share on other sites More sharing options...
