Wall Framing Issue
ACADuser
This is one of those remodel houses where the 1st floor ceiling is 8' & 10'.
I've chased those floor heights & have finally got them correct.
But the south 8' wall framing will not build correctly & I lost one of my 2nd floor walls in the area.
I have a ceiling plane defining the new 8' ceiling at the junction of the old & new portions of the house.
Anyone have a clue as to what is causing the framing to build short of 8'?
Gomez.zip
You don't have automatic wall framing turned on so you need to rebuild the wall framing in order to see the correction.
The Master Bath has the ceiling set at 120". Change to 96", rebuild the wall framing. For the closet, you'll need to make some modfications. You can use a room divider to split the room where it has 2 ceiling heights.
Show off!
Thanks Robert, after I added room divider in the corner of the Common area & the closet below and playing whack-a-mole with the ceiling heights for 2 hours I finally got it, I think.
The wall did not build correctly in the corner but I can add studs to fill that.
Thanks again.
