skirby19 Posted October 21, 2021 Share Posted October 21, 2021 Trying to figure out how I can change the look of my boxed eave. See the example picture. I need the boxed eave to be flush with the column and arch. Any help is grateful. Link to comment Share on other sites More sharing options...
skirby19 Posted October 22, 2021 Author Share Posted October 22, 2021 Yes I did. I could not find how to do it. I only need the eave flush on the front, not the sides. Link to comment Share on other sites More sharing options...
DzinEye Posted October 22, 2021 Share Posted October 22, 2021 Pull back your roof gable overhang to be flush with the wall, then add a separate roof plane for the overhang area and turn off the boxed eave. Link to comment Share on other sites More sharing options...
Dermot Posted October 22, 2021 Share Posted October 22, 2021 When you select "Boxed Eave" in the Build Roof dialog, you should see some other options. One of these options is "Flush Eave". The built in help system actually does a fairly good job explaining how these options work. I think this is what Eric was getting at. 1 Link to comment Share on other sites More sharing options...
