Dimension Text - Horizontal Orientation
Ange822
Good morning, would anyone know how to show the dimensions text horizontally and not parallel to where the dimensions is being taken?
I am tried looking in preferences / setting / other chief talks with no luck.
Much appreciated!
    32367
    Echodrewer
    Echodrewer
  • Similar Content
    • By SMB2021
      Since upgrading to x14 at least 2 of my co-workers in my department are having a text issue when saving as a PDF. I have not had the issue they're having but it's becoming an "inconvenience" that if they need something sent to PDF, those of us not having the issue will have to open the file and do it for them.
      I've attached some pictures of the issue vs what it's supposed to look like.
      Is anyone else having this issue and knew the solution to fix it?
      How it looks when they send to PDF
      vs how it looks when I send to PDF
    • By Emma04
      I use Chief architect pro x14. Is there a way to lock wall length once done with imputing all your walls? Every time I try and use the room divider tool my wall always changes lengths; I thinks its just because of the angle I watched a video on how to fix it and was just wondering if there an option to lock your walls from the dimensions changing and not just being able to select them because of the active layer display . I'm new to Chief architect and when I used Revit it had a lock constraint next to the dimensions line, so I never had this problem before. Does Chief Architect not have this as a feature?
    • By jbur91
      Using Chief X12 and have a question about rounding.
      Is there a way to make dimensions round to the nearest fraction? Using the manual dimensioning tools, the program is rounding inconsistently. For example, I have my current dimension defaults set to show fractions to the nearest 1/2". However, it won't round to the nearest 1/2", it will only round down. One measurement in particular is 10'-4.94", and it's showing up on the floor plan as 10'-4 1/2" instead of 10'-5" like I want it to. This is causing exterior dimensions to appear inconsistent and is overall a huge headache for me.
      Is there some setting I'm not aware of that is preventing the dimensions from rounding up when I need them to?
      Thanks,
      Jack
    • By SMB2021
      Our company uses OneDrive for our file system. The company also has particular fonts they use for documents. Our Template plan file and layout file use those fonts but there's an issue with that. Anytime one of us opens a plan file or layout file (whether it's a new blank one or for an existing project) we get the 'Replace Fonts' Dialog box asking us to replace the missing font (company font) with another. Is there a way to get it to stop asking that each time and remember where the font is?
      We all have the font installed on our individual laptops. The fonts are also found on OneDrive. I've followed the article about this issue but the solution doesn't help since we all have the font installed but CA program can't seem to find it. Even if we replace the font with the same font (ie. it'll say 'Arial' font is missing and you select replace with 'Arial') that it doesn't actually replace it with that font. Once the file is open it chooses 'Verdana' font whether we choose the correct font we want or not.
      Any solutions that allow us to keep using the company font?
    • By Chiefuserodd
      Hey Mr. Chief Wizard,
      Is there a way to display only selected text in say a "Framing, Floor Plan View" active layer set that will not show up in the "Working Plan View"?  When I send to Layout, I would like specific text associated with the "Framing, Floor Plan View" to only show up on the "Framing" page and not on the regular plan view sheet that I have.
      Thanks,
