Demo wall dashing based on wall types, not layers
DeLayDesign
I've set up our walls to show demo'd walls to be dashed, but I'd also like that dashed line to show up in elevation as well.  Is there a way to do this, without moving the wall to a 'demo wall layer'.
I suppose I could edit all the walls so that anything that isn't to be demo'd isn't associated with the layer it's put on (remaining solid vs. dashed); but is there a better way?
I would also love for the siding/ brick, etc. to come in dashed as well if possible.
On 9/8/2021 at 11:17 PM, Alaskan_Son said:
Can you explain why placing onto a different layer isn't a good solution?
I'm in charge of the templates, and there are about 15 other users all with varying levels of competency.  It's extremely difficult to 'add steps' to a process they already struggle to understand and use fully.
Moving it to a new layer isn't a big deal, and if that's the only solution I'll do it.  I was just hoping it wasn't.  I'd rather the wall type show true through the floor plan and the elevations.
