KellySantaRosa Posted September 2, 2021 Share Posted September 2, 2021 Is there any way snapping to the components within a group without ungrouping them? I would like to draw a leader without having to pick all the individual pieces to regroup them afterward. Link to comment Share on other sites More sharing options...
SNestor Posted September 3, 2021 Share Posted September 3, 2021 9 hours ago, KellySantaRosa said: Is there any way snapping to the components within a group without ungrouping them? I would like to draw a leader without having to pick all the individual pieces to regroup them afterward. One way you could do it is to create a CAD Detail from View of the 3D block. You can do this without exploding the block. This will create cad lines for all the objects. You will probably have to explode some of the items as the CDFV will create "blocks" of some 3D objects. But...you'll have cad lines you can then copy of using "copy, paste and hold position" you will get lines to can snap to. It's a workaround really...and might be more trouble than exploding the block. Link to comment Share on other sites More sharing options...
