KellySantaRosa Posted September 2, 2021 Share Posted September 2, 2021 I am trying to adjust the default callout line weight and would like to know where in the defaults I can find this setting. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted September 2, 2021 Author Share Posted September 2, 2021 Thinking that default is here in 'text, callouts and markers', though I am now having trouble matching the cross section line weight. Is there any way to change the cross section line weight? The goal is a callout with a leader .. guess this can be built from individual lines then grouped, but this would lose the leader from following when fine tuning the callout position. Link to comment Share on other sites More sharing options...
SNestor Posted September 3, 2021 Share Posted September 3, 2021 @KellySantaRosa - the layer controls the default weight of the callout. If you set the layer to a lineweight of 10...you can open the callout and override the layer lineweight of the "cross section line" to make it whatever you want it to be. Thicker or thinner. The attached example shows the callout using the layer lineweight of 20...and the cross section line is using a lineweight of 50. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted September 14, 2021 Author Share Posted September 14, 2021 I am trying to figure out how to change the cross section line weight. Shown here is the dialog for a callout with line weight of 50 that only affects the callout but not the cross section line. Link to comment Share on other sites More sharing options...
SNestor Posted September 14, 2021 Share Posted September 14, 2021 @KellySantaRosa - Open the dialogue for the callout, navigate to the "attributes" tab and change the weight. This only changes the weight of the line itself. Change Attribute lineweight for Callout - Watch Video 1 Link to comment Share on other sites More sharing options...
KellySantaRosa Posted September 15, 2021 Author Share Posted September 15, 2021 thank you for the video! Link to comment Share on other sites More sharing options...
