BradAtHarmony Posted August 23, 2021 Share Posted August 23, 2021 I don't seem to have the General category showing on my material list in X13. When I open the Material List Specification DBX, it shows that the general tab should be displayed, but its not there... When I select just the General category I get a blank material list. Any ideas where I can get wall/window and door areas now? Or what I might be doing wrong? Thanks Brad Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted August 23, 2021 Solution Share Posted August 23, 2021 1 hour ago, BradAtHarmony said: Any ideas where I can get wall/window and door areas now? Or what I might be doing wrong? Thanks Brad File>Export>Export Thermal Envelope Data Link to comment Share on other sites More sharing options...
BradAtHarmony Posted August 23, 2021 Author Share Posted August 23, 2021 (edited) 51 minutes ago, Alaskan_Son said: File>Export>Export Thermal Envelope Data Huh.... I don't have that menu option on my Mac... I have the most up to date version. I'll have to contact support Edited August 23, 2021 by BradAtHarmony Added info Link to comment Share on other sites More sharing options...
Dermot Posted August 23, 2021 Share Posted August 23, 2021 Quote I have the most up to date version. Check to see if you actually have 23.2.0.55. You can find your version using Help>About Chief Architect. 1 Link to comment Share on other sites More sharing options...
BradAtHarmony Posted August 23, 2021 Author Share Posted August 23, 2021 29 minutes ago, Dermot said: Check to see if you actually have 23.2.0.55. You can find your version using Help>About Chief Architect. I didn't.... The app said I was up to date, but found there was a newer version online. Thanks! Link to comment Share on other sites More sharing options...
