MarkMc Posted August 22, 2021 Share Posted August 22, 2021 This is for Gene and anyone else who wants. Note I left out the back- either make it as none in X13 or opening in earlier versions. Tall filler.mp4 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2021 Share Posted August 22, 2021 Thanks for the Play by Play for X13 Mark , appreciate it. *** 1st Set General Cabinet Default to always show closed Doors and Drawers On *** ........it will be invisible otherwise Mick. *** Cabinet Side Panels How To.plan *** 1st Set General Cabinet Default to always show closed Doors and Drawers ON Cabinet needs to be: 1.5" thick Countertop and Kick OFF Set Height as needed eg. 34 1/2" or 90" etc Set Depth - 24 13/16" if you want it to align with the Doors on Cabinets - 25.75" for Fridge Panels next to countertops. Framed Box construction with Separation 0" , and Stiles 0" Front needs to be side panel Inset Left Side : Side panel inset, (for this LH end panel) with Right Stile set to 3/4" ( reverse for RH) Right side is set to NONE Back is set to None Put Cabinet on a NEW Layer with an invisible line style , ie Cabinets, Base 2 ALDO needs to have cabinet doors/drawers layer displayed, (set to Black solid line-style) SAVE ITEM(S) TO LIBRARY AND RENAME AS APPROPRIATE ! *** the 1st step to set the General Cabinet Defaults is IMPORTANT.....it will be invisible otherwise Link to comment Share on other sites More sharing options...
