1.5 filler with panel attached vid
MarkMc
Thanks for the Play by Play for X13 Mark , appreciate it.
 *** 1st Set General Cabinet Default to always show closed Doors and Drawers On ***  ........it will be invisible otherwise
Mick.
  1.   *** 1st Set General Cabinet Default to always show closed Doors and Drawers ON
  2.
  3.  Cabinet needs to be:
  4.
  5.   1.5" thick
  6.   Countertop and Kick OFF
  7.   Set Height as needed eg. 34 1/2" or 90" etc
  8.   Set Depth  - 24 13/16"     if you want it to align with the Doors on Cabinets
  9.                       - 25.75"          for Fridge Panels next to countertops.
  10.   Framed Box construction with Separation 0" , and Stiles 0"
  11.   Front needs to be side panel Inset
  12.   Left Side : Side panel inset, (for this LH end panel) with Right Stile set to 3/4" ( reverse for RH)
  13.   Right side is set to NONE
  14.   Back is set to None
  15.   Put Cabinet on a NEW Layer with an invisible line style , ie Cabinets, Base 2
  16.   ALDO needs to have cabinet doors/drawers layer displayed, (set to Black solid line-style)
  17.   SAVE ITEM(S) TO LIBRARY AND RENAME AS APPROPRIATE !
  18. *** the 1st step to set the General Cabinet Defaults is IMPORTANT.....it will be invisible otherwise
