Foundation walls are inset and cant figure out why.
Markenbach
I'm just beginning using CA, so still trying to figure stuff out.
Im using a company provided template and when I try and add a foundation, I keep getting this:
The walls are inset in a bizarre way that doesn't happen with the default template and I'm trying to figure out what setting would be causing this behavior.
Any ideas?
fyi, I don't know much about technical architecture, and its relative terminology. We're using this software more for visual prototyping.
Not sure exactly what you're after, but you have multiple potential problems.  Some of them lie with the foundation walls, but I think most of them lie with the the walls being used on your first floor.  I would suggest you create a new wall type (a copy even) with these 2 settings changed...
