puntloos Posted August 11, 2021 Share Posted August 11, 2021 I am currently running a raytracing walkthrough. ETA 1 day+. And now I'm stuck waiting for it to complete. Why can I not run another instance? Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted August 11, 2021 Solution Share Posted August 11, 2021 You can so long as it works to share computing resources. Hold down your CTRL key while you start the second instance. It is just not a recommended thing to do. Link to comment Share on other sites More sharing options...
puntloos Posted August 11, 2021 Author Share Posted August 11, 2021 ah great, that's the trick I was missing. Yep the program works just fine running twice. I guess I'll have to be somewhat careful trying to edit the exact same file so better make a copy etc. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 11, 2021 Share Posted August 11, 2021 On 8/11/2021 at 5:08 PM, puntloos said: I guess I'll have to be somewhat careful trying to edit the exact same file so better make a copy etc. Expand Yes you need to be very careful that if you have the same file open in two instances that one file is only used as a reference or you will end up with quite a mess. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2021 Share Posted August 11, 2021 On 8/11/2021 at 5:08 PM, puntloos said: I guess I'll have to be somewhat careful trying to edit the exact same file so better make a copy etc. Expand I'm not sure I understand why you need to open the second instance at all. There should be no reason you can't continue to work with the open instance where the Ray Trace is running. Link to comment Share on other sites More sharing options...
puntloos Posted August 11, 2021 Author Share Posted August 11, 2021 On 8/11/2021 at 7:21 PM, Alaskan_Son said: I'm not sure I understand why you need to open the second instance at all. There should be no reason you can't continue to work with the open instance where the Ray Trace is running. Expand Ray tracing of a walkthrough. X13 is fully 'frozen' with a "frame x out of xxx" window slowly progressing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2021 Share Posted August 11, 2021 On 8/11/2021 at 9:38 PM, puntloos said: Ray tracing of a walkthrough. X13 is fully 'frozen' with a "frame x out of xxx" window slowly progressing. Expand I see. I glossed over the "walkthrough" part. Link to comment Share on other sites More sharing options...
