Scotbow Posted August 6, 2021 Share Posted August 6, 2021 I can't figure out why the garage walls and footings are so much lower than the floor, and also the remainder of the house. The settings look to be the same for the garage, (as a rooom), as compared to the Kitchen for example. The monolithic slab settings also appear to be the same, except the garage shows a floor level of -4". Not sure how this is different when the same settings for the kitchen, show a floor level of 0". Thanks in advance for your help. Scott Loft 8-6-2021.zip Link to comment Share on other sites More sharing options...
HumbleChief Posted August 6, 2021 Share Posted August 6, 2021 The garage of the plan I opened does not show as a monolithic slab foundation. I think if it were me I'd rebuild the foundation as a mono slab and set the garage floor height (which is usually 4 - 6" lower than the main room heights but can be the same) in the rebuild foundation dialog box. It will clean up the floor height issues. Link to comment Share on other sites More sharing options...
Scotbow Posted August 6, 2021 Author Share Posted August 6, 2021 Thank you for your help. It's funny how I can look at something numerous times, and not see the issue. Link to comment Share on other sites More sharing options...
