ACADuser Posted August 5, 2021 Share Posted August 5, 2021 I create the attached elevation lines with dimensions and block them so I can paste in all elevation views. But when blocked the dimensions disappear. I have to create them during a Block Edit. Is this normal behavior? Link to comment Share on other sites More sharing options...
glennw Posted August 6, 2021 Share Posted August 6, 2021 I think the problem is that you are not including in your selection all the objects that are referenced by the dimension. Dimensions are only included in a cad block when all the objects they dimension are included in the block. This is a cad block including dimensions: 1 Link to comment Share on other sites More sharing options...
ACADuser Posted August 6, 2021 Author Share Posted August 6, 2021 Oh, I'll check that tomorrow. Link to comment Share on other sites More sharing options...
