CreekMan Posted August 3, 2021 Share Posted August 3, 2021 Hello all, I am at my wits end here with my tree materials. I have transparency on my texture images (png format) for the branches. When I change the materials on one tree in the foreground, looks fine (before picture). If I change the material on the tree behind it, the foreground tree becomes see though (after picture). Thoughts ? Is there a draw order in 3D view ? If I ray trace they are fine but don't want to have to ray trace for every concept image. My plan file is 70MB so cannot upload. Link to comment Share on other sites More sharing options...
CreekMan Posted August 3, 2021 Author Share Posted August 3, 2021 Another example view Link to comment Share on other sites More sharing options...
rlackore Posted August 3, 2021 Share Posted August 3, 2021 I've experienced anomalies with trees and transparency when in standard view, but it resolves in a raytrace. have you tried a raytrace? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2021 Share Posted August 3, 2021 3 minutes ago, rlackore said: I've experienced anomalies with trees and transparency when in standard view, but it resolves in a raytrace. have you tried a raytrace? 18 minutes ago, CreekMan said: If I ray trace they are fine but don't want to have to ray trace for every concept image. Link to comment Share on other sites More sharing options...
rlackore Posted August 3, 2021 Share Posted August 3, 2021 I missed your comment about raytracing - sorry. Anyway, you're not alone in having issues with standard view. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2021 Share Posted August 3, 2021 Have you tried hitting F5, F12, and/or clicking Rebuild 3D? I find sometimes that these types of issues are cleared up by a Rebuild/Refresh. Link to comment Share on other sites More sharing options...
CreekMan Posted August 3, 2021 Author Share Posted August 3, 2021 Tried all three (F5, F12 and rebuild 3d) to no avail unfortunately. I am wondering if it is something I did in 3ds/sketchup because it is not affecting all the trees, just the ones that have transparency in the texture file. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2021 Share Posted August 3, 2021 I’m curious...what happens if you modify those files to replace the transparency with a “green screen” of sorts so you could just use Chief’s transparency slider instead. It might not do anything. I’m not sure. I’m away from my computer now and can’t remember whether or not Chief’s symbols use images with or without transparency of their own. Link to comment Share on other sites More sharing options...
CreekMan Posted August 4, 2021 Author Share Posted August 4, 2021 Was worth a shot, the slider just makes the whole texture more transparent instead. I may just have to live with it as I was probably just trying to get too fancy, lol. I have attached the texture file though (made in GIMP) Link to comment Share on other sites More sharing options...
CreekMan Posted August 4, 2021 Author Share Posted August 4, 2021 For reference to all that have run up against this, it must be a program limitation of some sort. I tried using a chief core fire material that had an alpha channel png for source texture and this was the result. Green tree on left shows straight through. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2021 Share Posted August 4, 2021 19 hours ago, CreekMan said: Was worth a shot, the slider just makes the whole texture more transparent instead. Sorry, I misunderstood what you were doing the first time around. I thought you were having problems with a plant image when you were really having problems with a material that you were applying to a 3D plant. I just read too quick and wasn't comprehending your problem properly. Link to comment Share on other sites More sharing options...
CreekMan Posted August 4, 2021 Author Share Posted August 4, 2021 No worries, I should have been more clear. Link to comment Share on other sites More sharing options...
AtlasBuildingGp Posted July 2, 2024 Share Posted July 2, 2024 x15 I still have this problem , Did you ever find a solution. Link to comment Share on other sites More sharing options...
