Door/window surrounds
KevinCochran
Just like you would build it. Take an elevation view and apply them to the veneer. Look in the millwork catalog.
Automagically...you can use the millwork for the exterior trim. Check the box for LINTEL and add that top piece, use the sill tab to simulate the...well...sill.
You will most likely have to create the lintel piece as a molding line and save it to your user library. Make sure you check mark the RETURN box so that it returns to the brick and use the extend function to get it to go past the side pieces as it returns.
1 hour ago, KevinCochran said:
I'd like to add a limestone crown moulding and wall cap at the top of the parapet wall.  Not sure if that's something you could help with?  I opened one of the wall spec boxes and couldn't figure out how to do it that way.
Look for 'wall cap'
