Custom Window Glass issue
jtcapa1
For years, I've been spaying or using the rainbow tool to apply a custom stain glass pattern to windows, and now I've tried to set up my own folder with custom patterns.
I have run into an odd problem and I'm hoping you guys can help me sort out what I've done wrong?
  • I created a *.png image of stain glass
  • I then created a user folder called "Stain Glass"
  • I then  created a new material, that I pulled in the image, set as a general material
  • I then tried to get the right horizontal and vertical offsets
  • I inserted a standard window, selected material "Glass" and changed to my custom one
It seems to paint the image on both the inside and the outside, but reversed.
I like the look, but how do I get it not to have two  images?
There are likely a few methods that would work, but to avoid having to use a symbol window I would just take a cad detail from view of the window from and elevation view and then copy a polyline of the glass area back to the elevation view and snap a face to the polyline and paint that then carefully position it in plan view on the surface of the glass..
The problem is that the chief glass is essentially a polyline solid with 6 faces.  Four edges and then a front and back and I don't think there is a way to have a material map to that properly.
The "face" only has a single face so it works great for stained glass or fly screening.
