jtcapa1 Posted July 28, 2021 Share Posted July 28, 2021 For years, I've been spaying or using the rainbow tool to apply a custom stain glass pattern to windows, and now I've tried to set up my own folder with custom patterns. I have run into an odd problem and I'm hoping you guys can help me sort out what I've done wrong? I created a *.png image of stain glass I then created a user folder called "Stain Glass" I then created a new material, that I pulled in the image, set as a general material I then tried to get the right horizontal and vertical offsets I inserted a standard window, selected material "Glass" and changed to my custom one It seems to paint the image on both the inside and the outside, but reversed. I like the look, but how do I get it not to have two images? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 28, 2021 Share Posted July 28, 2021 There are likely a few methods that would work, but to avoid having to use a symbol window I would just take a cad detail from view of the window from and elevation view and then copy a polyline of the glass area back to the elevation view and snap a face to the polyline and paint that then carefully position it in plan view on the surface of the glass.. The problem is that the chief glass is essentially a polyline solid with 6 faces. Four edges and then a front and back and I don't think there is a way to have a material map to that properly. The "face" only has a single face so it works great for stained glass or fly screening. Link to comment Share on other sites More sharing options...
