Cabinet material question
DzinEye
Go to solution Solved by MarkMc,
I've got to believe this is possible, but apparently I'm not coming up with the right search criteria.   I would like to change the material of only certain drawers and doors from the default material without changing the material on the rest of the doors/drawer faces on the same cabinet.
  • Solution
Need to specify a new door/drawer for it. You can just rename them in library. Then they will allow different materials.
You can change the material of the renamed symbol in the library, use a style palette, or in rare cases set as default cabinet.
