Pdf To Dwg
bendintheriver
Even if you convert the PDF to DWG or indeed, if you bring a DWG file directly into Chief you can not modify the DWG in any sort of 3 dimensional way if that is what you mean.
You can work the 2D DWG file in the 2D Chief mode but that is the extent unless you build the Chief model on top of the PDF or the DWG.
Andy.
