Dawn0310 Posted July 19, 2021 Share Posted July 19, 2021 Hello! I'm trying to build an elevated, split level deck off the back of an existing house. No exactly sure if I'm on the right track. The larger stairs will change. But having trouble with the platforms. Basically, this is not my wheelhouse and could use some guidance. Much appreciated! Link to comment Share on other sites More sharing options...
Kbird1 Posted July 19, 2021 Share Posted July 19, 2021 Is auto generate Framing on in the Deck Room DBX ? you might want to turn on deck framing , posts, beams etc in the camera view The posts/footings will build down to the Terrain auto ....if you have one ? ( also not displayed in this camera if there?) There are a number of short tutorials in the KB as well if yu are new to Decks and using Railings to define them..... https://www.chiefarchitect.com/support/category/226/decks.html https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 M. Link to comment Share on other sites More sharing options...
LightHouse_Doug Posted July 21, 2021 Share Posted July 21, 2021 On 7/19/2021 at 1:46 PM, Dawn0310 said: Hello! I'm trying to build an elevated, split level deck off the back of an existing house. No exactly sure if I'm on the right track. The larger stairs will change. But having trouble with the platforms. Basically, this is not my wheelhouse and could use some guidance. Much appreciated! What problem with the platforms are you having exactly? What are you trying to do? Link to comment Share on other sites More sharing options...
