Chief5Me Posted July 5, 2021 Share Posted July 5, 2021 I'm trying to make a shed roofed wall dormer manually while following the "Creating a Manual Wall Dormer" tutorial. I've gone as far as the step pictured in the first screen shot; creating break points in the roof so that I can pull it back to create the dormer roof. The problem is whenever I select the break tool, it deselects the roof and won't allow me to create break points. Is there some setting I need to change? Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted July 5, 2021 Solution Share Posted July 5, 2021 Just guessing, but I suspect you are activating the Break Wall tool and not the Add Break tool in your edit menu. They're 2 different tools. Link to comment Share on other sites More sharing options...
Chief5Me Posted July 5, 2021 Author Share Posted July 5, 2021 Oh, wow! Many thanks to both of you, I never knew that they were different tools! Link to comment Share on other sites More sharing options...
SNestor Posted July 5, 2021 Share Posted July 5, 2021 I’ve made a few “dormer” videos that might help you. 1 Link to comment Share on other sites More sharing options...
