capitaldesigns Posted July 3, 2021 Share Posted July 3, 2021 I am working on a patio with a vaulted roof. The client wants 1x6 T&G sheathing under the exposed rafters. I am using wood planking for the ceiling finish on the under side of the roof. The problem I am having is having this finish continue on the under side of the eave over hang. Does anyone know how to get the wood planking to continue out under the roof over hang ? Ngai Design 1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted July 3, 2021 Share Posted July 3, 2021 Link to comment Share on other sites More sharing options...
capitaldesigns Posted July 3, 2021 Author Share Posted July 3, 2021 Hi Chopsaw, What you show is what I am look for. I tried doing what you show in your screen shot and it does not show up. See attached screen shot. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 3, 2021 Share Posted July 3, 2021 You also need to turn on the soffits in the structure panel but you have been doing this a while now Mike, so you also know you will need to rotate the material 90 degrees to keep your contractor happy. Link to comment Share on other sites More sharing options...
capitaldesigns Posted July 3, 2021 Author Share Posted July 3, 2021 That did it. The only time I have checked the soffit under the structural panel is when I was placing a flat soffit under the eaves. Thank You, Mike Link to comment Share on other sites More sharing options...
Chopsaw Posted July 3, 2021 Share Posted July 3, 2021 You could have actually saved some time by using the room structure setting of "Use Soffit Surface for Ceiling" and then you only need to apply the material one place. Try that next time maybe. 1 Link to comment Share on other sites More sharing options...
KBCASC Posted July 3, 2021 Share Posted July 3, 2021 10 hours ago, Chopsaw said: You could have actually saved some time by using the room structure setting of "Use Soffit Surface for Ceiling" and then you only need to apply the material one place. Try that next time maybe. This Option works well (best) for this... KB. Link to comment Share on other sites More sharing options...
