ADallas Posted June 28, 2021 Share Posted June 28, 2021 First day with Chief Architect, so this is a newbie tip for sure. I came across Edit > Preferences > CAD. In the Sun Angle section, you want to set your project's latitude and longitude. The default is Blanchard, Idaho. You don't have to change it for every project in the same region, but if you're in Texas, it will likely make a difference. My tip is how to find your latitude and longitude. Go to https://www.google.com/maps. Search for a specific address, or your town, and look at the URL in the address bar: The URL will start something like this: https://www.google.com/maps/place/Galveston+Island/@29.2147787,-95.0591303,11z/ The first number after the @ sign is the latitude. Select North if the number is positive, South if it's negative. The second number is the longitude. Select West if the number is negative (as in, the western hemisphere) or East if the number is positive (such as most of Europe and Asia). Hope it helps. 1 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 28, 2021 Share Posted June 28, 2021 Good tip. To add to it though: If you're using Google, you can actually just right click anywhere on the map and then left click on the coordinates that pop up and they'll copy to your clipboard... 1 Link to comment Share on other sites More sharing options...
nikiley Posted August 8, 2021 Share Posted August 8, 2021 I like to use the Compas app on my iPhone. I hold it up to the edge of the left facing wall of the house and take a quick screenshot. It has the direction I need to rotate my north arrow, as well as my long/lat data. Easy peasy. Link to comment Share on other sites More sharing options...
DefinedDesign Posted April 22, 2024 Share Posted April 22, 2024 On 6/28/2021 at 5:27 PM, ADallas said: First day with Chief Architect, so this is a newbie tip for sure. I came across Edit > Preferences > CAD. In the Sun Angle section, you want to set your project's latitude and longitude. The default is Blanchard, Idaho. You don't have to change it for every project in the same region, but if you're in Texas, it will likely make a difference. My tip is how to find your latitude and longitude. Go to https://www.google.com/maps. Search for a specific address, or your town, and look at the URL in the address bar: The URL will start something like this: https://www.google.com/maps/place/Galveston+Island/@29.2147787,-95.0591303,11z/ The first number after the @ sign is the latitude. Select North if the number is positive, South if it's negative. The second number is the longitude. Select West if the number is negative (as in, the western hemisphere) or East if the number is positive (such as most of Europe and Asia). Hope it helps. Thank @ADallas this was very helpful! Link to comment Share on other sites More sharing options...
