plannedRITE Posted June 28, 2021 Share Posted June 28, 2021 Evening everyone. I definitely wish that dormers happened to be simpler (or rather would hold my hand more) here within Chief (x12) as I seem to fight with it frequently. The latest issue is really odd to me. I was able to make the dormer show proper by moving them to the attic floor so that they would stop failing due to hitting attic walls (that even if deleted still keep the dormers from showing) but for some reason the roof will not show in the perspective floor overview. Oddly, they show on the plan, elevation views, and on the full camera view. Obviously this is not a huge issue but it's a bit annoying as I'm flying through and checking the model. So I have 2 questions. First, any idea why they would not show on just that 3d view? They layer is on but hopefully it's a simple oversight on my part. Second question is when I manually delete attic walls on the 2nd floor in this plan, why do they persist as invisible walls? If I delete the invisible wall they just reappear as attic walls again. As always, thank you everyone for your time! Orchard Ranch REV3.plan Link to comment Share on other sites More sharing options...
plannedRITE Posted June 28, 2021 Author Share Posted June 28, 2021 I'm assuming that you are referring to floor vs full overview? Ah, it's due to drawing roof planes in the attic view. That makes sense. I'm used to using the floor overview with the roof plans drawn on the first/2nd floor. Allows me to easily cut each level off the build to look inside. Guess I don't have that option here other than the cross section slider unless I can get the dormers to show properly on the 1st or 2nd floor. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2021 Share Posted June 28, 2021 1 hour ago, plannedRITE said: Second question is when I manually delete attic walls on the 2nd floor in this plan, why do they persist as invisible walls? If I delete the invisible wall they just reappear as attic walls again. 2.) ALT+Q uncheck Auto Attic Walls > delete walls not needed > Re-enable with ALT+Q again..... Mick Link to comment Share on other sites More sharing options...
plannedRITE Posted June 28, 2021 Author Share Posted June 28, 2021 58 minutes ago, Kbird1 said: 2.) ALT+Q uncheck Auto Attic Walls > delete walls not needed > Re-enable with ALT+Q again..... Mick Ah there it is, thank you Mick! Link to comment Share on other sites More sharing options...
