BruceKC Posted June 7, 2021 Share Posted June 7, 2021 My layer set management icon is missing in X13, so I tried to add it. I did that, but disappears as soon as I close the customize toolbars window. What am I doing wrong? Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 7, 2021 Share Posted June 7, 2021 16 minutes ago, BruceKC said: My layer set management icon is missing in X13, so I tried to add it. I did that, but disappears as soon as I close the customize toolbars window. What am I doing wrong? When in the Edit Toolbars Tool, in the panels named Tools, and Toolbar, under the View Type section, the View Type indicates which view you are adding a Toolbar to. If you want your user added Toolbar to show up on all views, make sure it is checked in the Toolbar Panel under the Toolbars Section for each associated view you would like that Toolbar to show up in Link to comment Share on other sites More sharing options...
BruceKC Posted June 7, 2021 Author Share Posted June 7, 2021 Thanks for the help. I did that and it now shows in Plan view, but I don't see any way to "check" each view. For now though, that helps a lot. Thanks. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 8, 2021 Share Posted June 8, 2021 18 hours ago, BruceKC said: I don't see any way to "check" each view. He was talking about this. In the following example, mine are all unchecked because I have no need for the tool... Link to comment Share on other sites More sharing options...
BruceKC Posted June 8, 2021 Author Share Posted June 8, 2021 Thanks so much, I've not seen that window, but now I see it. You are all so great at helping newbies!!!! Truly appreciate it. Link to comment Share on other sites More sharing options...
