Doug-ib Posted May 21, 2021 Share Posted May 21, 2021 Im doing a walkthrough for promo material, this is very early stages and this is a 10 FPS render just so you can see the issue. when i enter the building the rooms become very dark and dim looking. id like to brighten this up, i have tried setting the lights to 10k lumens but this was the result. Any tips or info to brighten the inside up would be greatly appreciated. (NOTE: I do have to render with shadows turned off as if not it takes me 3-5 hours for a rendering) any info is greatly appreciated. Untitled 1.mov Link to comment Share on other sites More sharing options...
Chopsaw Posted May 21, 2021 Share Posted May 21, 2021 Balance out your "Interior Ambient:" light level with your "Daytime Ambient:" light level. Maybe find an average between the two as the exterior light level seems a bit washed out to me. That should get rid of the change when you come inside. Link to comment Share on other sites More sharing options...
