Sloped/rounded Wall
Mark60103
I've done this using a room molding polyline. Drag it to line it up with the exterior of your wall instead of the interior. Use the rounded handrail molding, set the width to be the same as your wall and increase the height to three or four inches. It not perfect at the corners, but gives you a rounded parapet top. I'm sure you could do the same thing with an angled molding profile.
