dshall Posted May 5, 2021 Share Posted May 5, 2021 We still can't control HEADER LINES? I can't believe it! I think this topic pops up now and then, this is dumb. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 5, 2021 Share Posted May 5, 2021 Scott, I thought it was the "Top Edge Lines" that we could not control ? It seems that the "Opening Header Lines" are on a layer and can be controlled. That must be what you are using but would like the "Top Edge Lines" to have the same level of control ? Link to comment Share on other sites More sharing options...
dshall Posted May 5, 2021 Author Share Posted May 5, 2021 1 hour ago, Chopsaw said: Scott, I thought it was the "Top Edge Lines" that we could not control ? It seems that the "Opening Header Lines" are on a layer and can be controlled. That must be what you are using but would like the "Top Edge Lines" to have the same level of control ? Thanks Chop, you are kind of correct. 2 problem with that: 1- It cannot be controlled on a door by door basis 2. the opening header lines is for the header, I want it to highlight the arch opening including the drywall, not the arch opening framing so... we still need control of the TOP EDGE LINES...... thank you very much Link to comment Share on other sites More sharing options...
