RobWhite Posted May 4, 2021 Share Posted May 4, 2021 I have used the curved stair tool to draw a spiral stair case. Is there an adjustment to produce a round outer circumference instead of the polygon configuration? Current view, as attached below shows straight edged at each tread which produces an polygon rather than a circle. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 4, 2021 Share Posted May 4, 2021 10 minutes ago, RobWhite said: I have used the curved stair tool to draw a spiral stair case. Is there an adjustment to produce a round outer circumference instead of the polygon configuration? Current view, as attached below shows straight edged at each tread which produces an polygon rather than a circle. You can do this using landings instead of the staircase tool, You have to do some trickery to be able to control stringers though. Image on the right is landings Link to comment Share on other sites More sharing options...
