Why Isn't Line Weight In Plan And Layout The Same?
Nicinus
Perry:
I don't understand how anno-sets relate to the steps Glenn listed in post #15 ???
I don't use anno-sets but I understand the basic principles
yet, that doesn't correlate with me concerning what Glenn posted
My understanding would be to use Glenn's steps first
then use anno-sets as you describe
Lew
Ok, so I'm doing exactly what I think you guys are saying. First I create a simple (albeit admittedly weird) little floor plan and make all normal walls 50 (double the old rotring  :) ) as per below:
As you can see most lines are thin even though the 'Line Weight' icon is toggled on, in fact no difference except on dotted lines when I toggle it.
The "Walls, Normal" line weight will only be used if the individual wall layers are turned off. If the layers of the wall are turned on, then the line weights will be taken from the wall definition.
EDIT: Oops, sorry. Just saw that Glenn W. mentioned this.
