RobertJr Posted April 15, 2021 Share Posted April 15, 2021 OK, the default roof is set to a 5/12 pitch. When I create the plan, the automatic roof that is created has a 6/12 pitch. When I check the default settings, the default roof is still 5/12, so I manually change the roof plains to 5/12 and set them to hold. If I change a room again, with the auto build button checked, some of the roofs revert to a 6/12 pitch even though they are set to "hold" the 5/12 pitch. It's becoming frustrating. What am I missing? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 15, 2021 Share Posted April 15, 2021 The wonderful thing about this software is that there are may ways to do things although sometimes it will turn around a bite you. There is a default that can be overridden by manual changes as well as wall settings and roof polylines and that is all that I can think of quickly but there may be more. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 15, 2021 Share Posted April 15, 2021 Just a guess, but sounds to me like you probably edited your Exterior Wall Defaults to use a non-default pitch. Try opening up your Exterior Wall Defaults, click on the Roof tab and make sure the little Use Default wrench icon has a check on it. Link to comment Share on other sites More sharing options...
