ACADuser Posted December 4, 2014 Share Posted December 4, 2014 I modified a landing & it hides the door swing. No Bring To Front for the door. Also I modified a polyline solid and it hides the door swing. Both have a lower elevation than the door so the drawing order in the database must be the problem. So how to bring the door swing to top of group? Link to comment Share on other sites More sharing options...
joey_martin Posted December 4, 2014 Share Posted December 4, 2014 Move the landing to the back or default position....or simply remove the fill from the landing. Link to comment Share on other sites More sharing options...
ACADuser Posted December 4, 2014 Author Share Posted December 4, 2014 I used the transparent feature to fix it but how do you move to BACK? Thanks Link to comment Share on other sites More sharing options...
joey_martin Posted December 4, 2014 Share Posted December 4, 2014 Select the landing and open the DBX. Use the radio buttons to select which level the landing is on. BACK, DEFAULT, FRONT. Depending on which level, you can then move the item to the front of the GROUP by selecting the button to do that. For instance, if you have multiple items on the same group and need one particular item in that group to display on top, you set the FRONT OF GROUP for just that item. Link to comment Share on other sites More sharing options...
ACADuser Posted December 4, 2014 Author Share Posted December 4, 2014 Thanks, learn something new every day. Link to comment Share on other sites More sharing options...
