ACADuser Posted April 9, 2021 Share Posted April 9, 2021 So I changed the Window Default to "Specify Label" and added this: %automatic_description% Top @ %height% But the new windows in plan view default to "Automatic label" is this normal behavior? I would also like %height% to be Feet - Inches, do I need a user macro to do that? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 9, 2021 Share Posted April 9, 2021 Hopefully this will be a whole lot easier in X13 but changing the default for windows only seems to apply to newly placed windows, so you would need to open all your existing windows and use a Number Formatter for the height value. ie. Top @ %fi(height)% Here is Eric's explanation: Link to comment Share on other sites More sharing options...
ACADuser Posted April 9, 2021 Author Share Posted April 9, 2021 Yes but NEW windows placed in the plan did not use the "Specify Label" they still use "Automatic label" I was looking at Eric's routine as the only way to get feet & inches. Link to comment Share on other sites More sharing options...
ACADuser Posted April 9, 2021 Author Share Posted April 9, 2021 Scratch that it is working as you said. Not sure how I got off track. Link to comment Share on other sites More sharing options...
