Chopsaw Posted March 16, 2021 Share Posted March 16, 2021 Could someone confirm for me that when a Picture file contained in a Layout Box is rotated 90° that the Picture File rotates 180°. It would appear that as the Layout Box is rotated the Picture file rotating in the opposite direction at double the rate the box is rotating. Maybe I am seeing things incorrectly but if this is true that must take some pretty sophisticated programming. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2021 Share Posted March 16, 2021 Works just fine for me. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2021 Author Share Posted March 16, 2021 On 3/16/2021 at 2:41 AM, Alaskan_Son said: Works just fine for me. Expand In X12 ? Upside down.... I guess I need to try again. This just seem wrong for some reason. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2021 Author Share Posted March 16, 2021 It only seems to be happening in my CAD Details.... Same thing the dimensions are doing. Ug Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2021 Share Posted March 16, 2021 On 3/16/2021 at 3:04 AM, Chopsaw said: t only seems to be happening in my CAD Details.... Expand CAD Details seem to work fine for me as well. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2021 Author Share Posted March 16, 2021 On 3/16/2021 at 3:08 AM, Alaskan_Son said: CAD Details seem to work fine for me as well. Expand I give up ! Is there a setting somewhere the controls that ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2021 Share Posted March 16, 2021 On 3/16/2021 at 3:09 AM, Chopsaw said: I give up ! Expand Which part of your image is the Picture Box? Are you sending to layout from Plan or from Layout? If from Layout, is the image being placed directly in the CAD Detail or is it a Layout Box sent from a Plan? What text issue are you were referring to? And assuming the caution symbol is the picture box, can you just use simple Unicode caution symbol instead of a Picture Box? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2021 Author Share Posted March 16, 2021 On 3/16/2021 at 3:32 AM, Alaskan_Son said: And assuming the caution symbol is the picture box, can you just use simple Unicode caution symbol instead of a Picture Box? Expand Yes the Black and Yellow Triangular Caution Symbol is the Picture Box sent to layout from a Plan CAD Detail. I tried the Unicode Symbol first in a text box but it prints out as blue and not black and yellow in my PDF. Not a text issue but a dimensioning issue... They seem to think it is better to flip over 180° rather than just rotating 90° with the layout box. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2021 Author Share Posted March 16, 2021 And yes I could just rotate it in plan and all would be fine but I have two separate layouts with different orientation. Hoping I don't have to rotate all the rest of the sheets just for this because with my luck that would create a bigger issue somewhere else. Link to comment Share on other sites More sharing options...
