camera views in layout to big
woodcraftdesign
If you need to change the magnification then marque select the layout box and use the upper edit handle.
There is a much more complicated method to make it work the way it did by default several version back just by pulling on a corner.
Is that the method you are after like other programs ?
15 minutes ago, woodcraftdesign said:
The marquee select works great.  This is probly not exact as it should be.  where is the default setting for size of image at layout?  is this in the plan side or layout side?
Not really sure there is a default.  It is loosely based on the "Current Screen" magnification and cropping if you use that setting when sending to layout.  There is more control with sending an image rather than a live view but I don't know who does that now that we have live views.
The old method of dragging a corner is now:
Anchor the fixed corner and place a temporary point there and then make sure "Rotate/Resize about Current Point" is turned on and then finally hold your X key down and grab the opposite corner to resize.....    Whew....   Then don't forget to delete the temporary point.
  • 1 month later...
