Wall Line Weights
builtright3
29 minutes ago, DzinEye said:
Are you sure about that Richard?  Try setting your 'Walls, Main Layer Only" line thickness to something quite different from that in your normal wall definition and then toggle that layer... .my wall lines do not change.
After playing with this, you're right. This does not work the way I remembered it. "Walls, Main Layer Only" seems to be just a toggle now, with no functionality to the line weight or color.
If you place a wall (in the wall edit dialogue) on the "walls, main layer only" layer...then, when turn on this layer...the lineweight will change to whatever LW you have selected for this layer. I use it as a toggle...but, it can change the LW if you have checked the box in the wall edit DBX to use the layer for it's LW setting.
2021-03-03_16-55-02.thumb.png.e6d17f4f4dc6d7b2f36e0d0abdcfb00b.png2021-03-03_16-55-44.thumb.png.9ee6c4807fe267563b71d4c6ae54e325.png
