Ruby Question: Passing a value from one plan file to another
Doug_N
HI Ruby Geeks  :rolleyes:
I am using two plan files for a layout, one of the house and one for a detached two story garage.  In doing the site statistics I create ruby global variables for floor areas, exterior wall areas, ridge and eave heights for inclusion of a lot statistics analysis.
I do the tables in a cad detail file in the house plan file, but I can't find a way to pass the values of the variables in the garage plan file to the cad detail sheet in the house plan file.
Any ideas on how to do this, or a work around?
Doug
Doug
Globals are stored with the instance of Chief, not necessarily with the plan or layout file so it should already work like you want.  That being said, the variables need to be defined before you can use or display them elsewhere.  To help ensure this is happening, it can be useful to place a layout box containing the items generating the variables in the first place off to the side on your layout page where the variables are being used or displayed.
By Layout Page your are referring to the layout file?   Does that mean I should define the variables in the layout first, then use them in the plan file?
filename.layout >   page xxx    %$lotarea=999%
filename.plan >  First Floor (plan view)  [polyline shape] (label) %$lotarea= area.round(2)%
Something like that?
