kwhitt Posted February 18, 2021 Share Posted February 18, 2021 I'm trying to create a pie-cut corner wall cabinet. I've tried two methods and neither give me the appearance I'm after. The first image shows two individual wall cabinets meeting at the wall corner. As you can see the top rail overlaps back to each wall. The second image shows Chief's out-of-the-box corner wall cabinet. I don't want the additional frame stiles in the corner. I was hoping someone had a workaround for this other than building the cabinet using P-solids. @MarkMc Link to comment Share on other sites More sharing options...
kwhitt Posted February 18, 2021 Author Share Posted February 18, 2021 1 hour ago, MarkMc said: Ok in Standard One glitch in vector corner cabinet.plan Thanks Mark - clever as always! I knew you'd have an answer. Kevin Link to comment Share on other sites More sharing options...
cbdesign Posted April 8, 2021 Share Posted April 8, 2021 @MarkMc Hi, found this post and I'm struggling with the same thing. I downloaded the model you attached, and gone through it to match my cabinets to what you did.... I am trying to figure out what you did to remove the stiles in the corner of where the cabinets meet. Can you explain? Thank you so much! Link to comment Share on other sites More sharing options...
MarkMc Posted April 8, 2021 Share Posted April 8, 2021 20 minutes ago, cbdesign said: Can you explain? Open each cabinet DBX and check EVERYTHING- front and sides. Most of the things I post require you to do that to get an understanding of how things work. Link to comment Share on other sites More sharing options...
cbdesign Posted April 8, 2021 Share Posted April 8, 2021 Hi @MarkMc, thank you! See attached, in my cabinet settings the stiles settings aren't something I can edit. Link to comment Share on other sites More sharing options...
MarkMc Posted April 8, 2021 Share Posted April 8, 2021 1 minute ago, cbdesign said: Hi @MarkMc, thank you! See attached, in my cabinet settings the stiles settings aren't something I can edit. In cabinets I posted ope the other tabs to find what is different. Link to comment Share on other sites More sharing options...
cbdesign Posted April 8, 2021 Share Posted April 8, 2021 10 minutes ago, MarkMc said: In cabinets I posted ope the other tabs to find what is different. Thanks @MarkMc, I figured it out. Appreciate the help! I had to set the cabinets to be framed to be able to edit the stiles. Thanks again. Link to comment Share on other sites More sharing options...
