Trouble with Foundation changing
blueriver
I am building a monolithic slab.  I let chief build the perimiter and now i'm going through and adding additional beams.  When i pull this long running beam all the way over to the right side it changes the appearance of the beams on the right side. When i open the object i can't find anything different in the gray beams and white beams. Can anyone tell me why this is happening and how to make it stop?  I want all the beams to look the same.  (Right side is master bed, bath, etc)
Lauren,  If you draw a slab footing that is completely independent it will have fill by default.  However as soon as it is joined to another wall that has room definition it will loose that fill style.  Check to be sure your wall is properly connected but if for some reason it can not be connected then the fill can be removed from the wall definition.
