johnbds Posted December 8, 2020 Share Posted December 8, 2020 When I place trapezoid windows in the upper portion of a balloon framed gable wall which has windows and doors in the lower portion of the wall, they show on the wall floor plan and block out portions of the wall. I have tried placing the windows on a separate layer and not displaying that level on the floor plan, but that does not solve the problem. I have tried using the window vertical stacking option, but again no help. I tried to attach the plan file, but get a note telling me the file is too big, even after zipping it. Any help you all could provide would be much appreciated. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 9, 2020 Share Posted December 9, 2020 3 hours ago, johnbds said: When I place trapezoid windows in the upper portion of a balloon framed gable wall which has windows and doors in the lower portion of the wall, they show on the wall floor plan and block out portions of the wall. You can set those windows to use an Absolute elevation reference and place them in another wall on another level or in the attic or even the basement. The attic is usually the best option and then change your wall type to a room divider. Link to comment Share on other sites More sharing options...
