Framing Error Message
Robsyyz
Does your floor or ceiling structure have a framing layer?  If you are trying to build framing, then you should have a framing layer in your structure.
If you do, then I would recommend that you either post your plan or if all else fails contact tech support for more assistance.
Room Specification for a room in the existing portion of the house plan.  I was working on a plan for an addition attached to an existing house.  I had change the Default to match the existing 2x10 " floor joist layout in the existing part of the Plan, thats when the error message started to appear.
