Elevation Camera is clipping
Apollosg
Has anyone seen this before.  It was working fine.  I made some changes to the drawing and when I update the Layout i get a clipped elevation.  I created a new camera and I still get the same thing.  The drawing is large, so I thought I would start with screen shots first.
Old camera:
Refresh after update view:
I have looked in the defaults for the camera, the camera itself, but everything looks normal.  Not sure where else to begin.
Thanks,
Gary
Old camera:
Thanks,
Gary
Maybe try to open the camera dbx and see if clip to sides is checked?
2 minutes ago, Apollosg said:
@rgardner nothing there.  @solver I did.  I even went up to 3D and let it create a auto front elevation;
Is that wall that it is cutting off on a different layer that may be turned off in your elevation view?
uploading the plan file would probably get you some help.
