rgardner Posted August 2, 2022 Share Posted August 2, 2022 6 hours ago, Steve-C said: When this happens I close the plan and quit CA. When I reopen the plan my toolbars at the top are usually unchanged, but the side toolbars get crammed down to the bottom and I have to move them back up. And yes I do use dual 32" monitors, they are identical brand and resolution. Most likely it has to do with the custom toolbar spacing. If you are separating them by dragging them apart apparently that is an issue with something with mac in particular the limitations set on simple icons that chief uses. Use the toolbar empty space instead of separating them that way. It seems to have worked for me although the process above was done at the same time so it may have been a combination of the two. 1 Link to comment Share on other sites More sharing options...
