WayneG Posted October 21, 2020 Share Posted October 21, 2020 I have got two questions, first and most importantly why do these walls just keep going through the roof? I just cant figure this out. My second question is how do I get the 2nd floor bedrooms to extend up like in the picture that will match the existing roof. It looks like a dormer of sorts. I tried to cut a hole through the roof, but it didn't work out so well for me. Is there some setting that I have not checked? Thanks for a reply for someone Test Untitled 1.plan Link to comment Share on other sites More sharing options...
DzinEye Posted October 22, 2020 Share Posted October 22, 2020 I don't see any walls going through roofs? What're you talking about? Link to comment Share on other sites More sharing options...
DzinEye Posted October 22, 2020 Share Posted October 22, 2020 You have no rooms drawn on your 2nd floor, so it's quite difficult to offer help without spending a lot of time fumbling with guesswork. The roof in your picture could have been done at least three or more different ways, but since it's a straight-on front elevation it gives very little clue as to how they did it. Do you have a view from the side? If not, then you get to try modeling several of the possible solutions to see what you like best. Did you auto-build this roof? Note that the lower roof section of the roof in your picture is a lower pitch, then it steepens partway up. Your steep roof starting at the bottom will swallow up a 2nd floor. Link to comment Share on other sites More sharing options...
WayneG Posted October 22, 2020 Author Share Posted October 22, 2020 Hi DzinEye, I sent the model instead of a picture. I am very sorry for the confusion. Link to comment Share on other sites More sharing options...
