PB
decorators3
Hi
I've attached  a PB rendering ,I cant understand why one cabinet shows pink!!??  I tried using a slab door to the room instead of glass,, eliminate the wall light  .. still pink..  standard view is fine all other views are fine even ray trace but PB shows pink
Any suggestions?
Thanks
Change the material of the towel to something more like the intended appearance of the cabinet (That is the only source of "Pink" that I see in the room, you may be aware of another). Colors in PBR tend to be influenced by the presence of other colors being reflected on other objects, so look for and eliminate all the pinks and then see if that helps. In PBR colors and lighting are King and Queen.
