Wall offset problem
Gawdzira
I have an odd situation. I am doing a very small offset of 2 walls. Sure, the easy fix is to align the walls but they don't call me uneasy Al for nothin'.
in the images you can see that the roof framing is ignoring the attic wall and using the wall below to get the framing info so that 3d model is getting messed up by the framing members. I can delete the framing but then the soffit is short. In the image with the trapezoid highlighted, that is a hack fix for the siding. It is under a layer called Walls Hack Fix. Any ideas on a way to deal with this? Moving the walls is not the answer I am looking for.
Help me Mr. Wizard (for you Millennial's, Mr. Wizard was a hero of mine, as are most reptiles)
x12 file
LinCor start dd v4 b.zip
