winterdd Posted October 5, 2020 Share Posted October 5, 2020 every project is a new adventure. i want to have the the top of this polyline solid beam trimmed to the underside of the roof. would the outline have to be drawn in a elevation view then subtracted in a plan view? Link to comment Share on other sites More sharing options...
Chopsaw Posted October 5, 2020 Share Posted October 5, 2020 Draw all three pcs in an elevation view from the side. No subtraction necessary. That will be quite the beam. 30+ ' span ? Link to comment Share on other sites More sharing options...
winterdd Posted October 5, 2020 Author Share Posted October 5, 2020 Ok, so three pieces. I was trying to make it one. Not quite 30' span but have some more to do for sure. Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted October 5, 2020 Share Posted October 5, 2020 If you need to miter the corners then you need to add another step but try to draw it as it will be built as much a you can. Link to comment Share on other sites More sharing options...
winterdd Posted October 5, 2020 Author Share Posted October 5, 2020 5 minutes ago, Chopsaw said: but try to draw it as it will be built as much a you can. agreed. Link to comment Share on other sites More sharing options...
