Sign in to follow this
ChiefUserBigRob
trimming pline solids to angles
every project is a new adventure. i want to have the the top of this polyline solid beam trimmed to the underside of the roof. would the outline have to be drawn in a elevation view then subtracted in a plan view?
Draw all three pcs in an elevation view from the side.  No subtraction necessary.
That will be quite the beam.  30+ ' span ?
If you need to miter the corners then you need to add another step but try to draw it as it will be built as much a you can.
    28833
    Chieftan_1
    Chieftan_1
