Slab running bond block material 45 deg off on top face
Christina_Girerd
Why does a slab material have the top face 45 degrees off from the sides?  I was applying a running bond block material and was surprised that it looks incorrect.  Then I noticed that when I opened the Define Material dbx, the preview showed correctly.  I then tried applying it to a polyline solid and it showed correctly.  Is there any reason the slab should show the material differently or is this a bug?  The last image shows the slab on the left and the polyline solid on the right.
